[Qgis-user] qgis crashes when opening a GRASS raster and vector
maps
John C. Tull
john.tull at wildnevada.org
Mon Oct 13 13:47:33 EDT 2008
What version of qgis? Are you building or using a precompiled binary?
Are you using frameworks or source builds for support libraries? I
think more information is needed to help figure this out.
I have noticed some grass weirdness in trunk, but I have not tried any
of the older makes. Basically, I am getting errors reading grass
rasters after a certain number are already loaded. I have yet to file
a bug due to lack of time to better sort out the problem, but I will
try this week.
John
On Oct 13, 2008, at 7:01 AM, Kurt Springs wrote:
> Hi folks,
> I am running Qgis under OS X 10.5.5.
> I have been using the plug-ins to import the GRASS raster and vector
> maps. Each time I try to import the map, qgis quits with no warning
> and no message that it has unexpectedly quit. I was hoping someone
> could tell me why and how to fix it. I am running 1.0.0 preview,
> but it has been happening on the last couple of versions as well.
> I don't know if this means anything but I get a pop-up that says
> "QGIS couldn't find your GRASS installation. Would you like to
> specify path (GISBASE) to your GRASS installation. I have tried
> several things but none of them seem to satisfy this message. Could
> someone tell me what I should be aiming for to specify the path?
> Thanks in advance for your help.
> Kurt Springs
> Qgis-user mailing list
