[Qgis-user] QGIS and ECW and MrSid formats
William Kyngesburye woklist at kyngchaos.com
Fri Oct 31 13:29:36 EDT 2008
On Oct 31, 2008, at 11:57 AM, Tom Elwertowski wrote:
> GDAL provides a configure script to add GRASS support as a plugin
> rather then built-in. There are no configure scripts for ECW and
> MrSID but it should be possible to copy and modify the GRASS plugin
> build script. William must have either done this or written his own
> build routine since he has created working Mac GDAL plugins.
Yes, I originally started with a configured GRASS plugin makefile to
create makefiles for other plugins.  They're almost unrecognizable
now, and are tailored to compiling for the OSX framework (universal,
framework-only, no configure step), but could be easily extended to
support other systems.
Generally, get the OBJ list from the driver's GNUmakefile, and
discover the CFLAGS and LDFLAGS (include paths and external libraries)
needed for the format for your system by running configure as if you
wanted to build the formats into GDAL (values will be in gdalmake.opt).
Someone who knows autotools (or cmake) could make configurable
standalone source packages like the GRASS plugin.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Mon Dieu! but they are all alike.  Cheating, murdering, lying,
fighting, and all for things that the beasts of the jungle would not
deign to possess - money to purchase the effeminate pleasures of
weaklings.  And yet withal bound down by silly customs that make them
slaves to their unhappy lot while firm in the belief that they be the
lords of creation enjoying the only real pleasures of existence....
- the wisdom of Tarzan
