[Qgis-user] QGIS and ECW and MrSid formats
Paolo Cavallini
cavallini at faunalia.it
Fri Oct 31 14:26:56 EDT 2008
Martin Dobias ha scritto:
> - for linux the situation is more complicated. users usually use gdal
> packages from their distribution, so we would need to produce
> alternative packages for several distributions which would be
> compatible with original ones. Or create "qgis-with-gdal-ugly"
> packages with GDAL inside (but that would be nasty solution)
It is possible to compile ECW support in GDAL as a plugin:
http://wiki.gfoss.it/index.php/Come_abilitare_il_supporto_ai_file_ECW_in_GDAL_e_visualizzarli_in_GRASS_e_QGIS#Creare_un_plugin_GDAL_per_il_supporto_ECW_.28DRAFT.29
(in Italian, sorry, but bash commands are international).
All the best.
pc
Paolo Cavallini, see: * http://www.faunalia.it/pc *
