[Qgis-user] QGIS hanging and bad shapefile export
Gavin Fleming
GavinF at mintek.co.za
Wed Sep 10 02:15:23 PDT 2008
Hi
Two problems have been occurring regularly in QGIS (0.11 on XP)
1. Open attribute table, select one or more records, click 'Zoom to
selected records' - QGIS hangs.
2. Export as shapefile (PostGIS layer): ArcGIS does not recognise
the extent of the shapefile and will not draw it, though attributes are
accessible. If you then export it as a shapefile again from within
ArcGIS, the output shapefile is fixed and draws fine. Is this a PostGIS
/ shapelib / QGIS problem? What's the fix?
thanks
Gavin
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20080910/784cc6af/attachment.html>
