[Qgis-user] how to do continuous color with a special value
Christopher Barker
Chris.Barker at noaa.gov
Wed Sep 10 09:53:04 PDT 2008
Hi folks,
I have a set of data with a bunch of polygons, each of which has a value
representing a physical quantity. I'd like to symbolize them with a
continuous color scheme -- all is OK.
However, the data has a "nodata" value (99.9 in this case) that I would
like to use to make those polygons transparent. Is there any way to do
this without pre-processing the data to remove those polygons?
Also, there seem to be severe limitations on the continuous color
symbology anyway:
1) I'd like to be able to set what the minimum and maximum values are,
rather than it using the min and max form the data (that might even help
to solve my problem above -- the real data is between 0 and about 10,
but with th 99.9s in there, I don't' get a useful color ramp.
2) is there any way to apply and/or define a colormap? have a linear
shift form one color to another is very limiting. I don't know what GIS
systems usually provide, but scientific plotting packages usually
provide a bunch of stock colormaps (green to red, greyscale, etc, etc.),
suitable for different types of data.
thanks,
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R (206) 526-6959 voice
7600 Sand Point Way NE (206) 526-6329 fax
Seattle, WA 98115 (206) 526-6317 main reception
