[Qgis-user] measuring tool in error?
Magnus Homann
magnus at homann.se
Mon Sep 15 13:47:16 PDT 2008
Jim Hammack wrote:
> Another question regarding 0.11.0-Metis under Slackware 12.1. When measuring
> distances, the results are obviously incorrect. In the screen capture
> (http://unisips.com/qgis), I have measured from the end of the chain of green
> points to the coastline (the white line.) The distance is given as over 227,000
> degrees - clearly wrong. Shapefiles are geographic (lat/lon) in NAD83:
> +proj=longlat +ellps=GRS80 +datum=NAD83 +no_defs
> I just started using qgis and am extremely happy with it. I'm relatively new to
> GIS in general, so I'm not sure if I've found a bug or if I'm doing something
> wrong. Any help would be appreciated.
Did you have on-the-fly projection set?
Magnus
