[Qgis-user] HomeRange plugin updated
Anne Ghisla a.ghisla at gmail.com
Fri Apr 10 01:58:39 PDT 2009
John C. Tull ha scritto:
> Here is an error I get now using a shapefile with a set of points
> creating home ranges on field 'ID'. There is only one ID for all the
> points, so it should create a single home range estimate for each method.
> An error has occured while executing Python code:
> Traceback (most recent call last):
[cut]
> RRuntimeError: Error in writeOGR(khr.polygons, dir, name, "ESRI
> Shapefile") :
> GDAL Error 1: Failed to create file .shp file.
Bad thing. GDAL is the dependency I know (and care) less, assuming it
works independently of HR_plugin installation.
I would ask if you can run a pure R test, to check if the error comes
out from rgdal package or GDAL itself, like this one:
cities <- readOGR(system.file("vectors",package="rgdal")[1],"cities")
writeOGR(cities,tempdir(),"cities",driver="ESRIShapefile")
and see if it raises a similar error.
If the test above succeeds, you can comment line 102 of
HRplugin_algorithm.py and uncomment line 101, choosing suitable dir
parameter.
I'll look for more details about this issue - moreover, please fill a
ticket on AniMove Trac [0] if the problem persists.
thanks for testing,
Anne
