[Qgis-user] Relational Databases and PostGIS formatting of Vector
Data
Peter Willis
peterw at borstad.com
Thu Apr 9 14:49:09 EDT 2009
Carson Farmer wrote:
> AFAIK the PostGIS manager plugin is also able to load shapefiles into
> PostGIS, and this is a nice simple way to manage your database directly
> from within QGIS.
> Yes, I think you're probably right here. It would be difficult to create
> a tool that would import data into pgsql the way that everyone or anyone
> would like... so KISS is the best solution (keep it simple s...) from
> here it's up to the database maintainer to keep things the way they want
> it...
Well, there should be some type of organizational standard so that
applications, like QGIS, can query the database properly. Then again,
that could be handled by a database function that simply provides
a table/view of postgresql data in the proper organization.
> Th postgis user lists would probably benefit from this discussion, have
> you suggested similar things there? Most of us on the QGIS lists aren't
> database experts, so a better discussion would probably come out of the
> postgis lists.
No, I haven't suggested this on that list.
My only real worry was that if I import 200 vectors, I will end up with
200 different tables in the database...
Peter
