[Qgis-user] Project takes very long to load
Agustin Lobo alobolistas at gmail.com
Tue Apr 28 06:19:17 EDT 2009
Could we have this fixed asap for binary distributions? This is
a really important one in practical terms, and of general interest. (For
example, I have "real projects" split
in different qgs files because of this problem.)
Andreas Neumann wrote:
> Hello,
> I'd like to inform you that Jürgen provided a fix for the problem, which
> is now in trunk. Thank you Jürgen!
> The problem really was the primary key detection, which was checked with
> every project load and took very long for complex views/tables. Now the
> pkey check is done with the initial layer loading and stored in the
> project file. When loading the layer it seemse like it first starts the
> primary key detection with the stored key attribute from the project files
> and stops searching for further keys after it confirmed that the suggested
> key works - at least this is how I understand the current behavior in
> trunk - Jürgen - please correct me if I am wrong.
> Anyway - the project that previously loaded in 3-4 minutes now loads in
> approx. 10 seconds.
> I hope that this can still make it into the 1.1 release, as this is a big
> problem for people with more complex tables/views.
> Thanks,
> Andreas
> On Fri, April 24, 2009 10:59 am, Paolo Cavallini wrote:
>> Andreas Neumann ha scritto:
>>> Here is what I did so far:
>>> I saved the project as a different name. So far this did not speed
>>> things
>>> up. I did a project file comparison in the OxygenXML editor. There are
>>> only minor differences, like
>> Very detailed report, thanks a lot Andreas!
>> Hopefully jef will be able to understand what's going on.
>> If I can help with testing, just let me know.
>> All the best.
>> Paolo Cavallini: http://www.faunalia.it/pc
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-user/attachments/20090428/bccf173c/alobolistas.vcf
