[Qgis-user] Re: installing qgis on vista
maning sambale
emmanuel.sambale at gmail.com
Fri Aug 21 07:37:35 PDT 2009
It's finally running when I reinstalled
Microsoft Visual C++ 2008 Redistributable Package (x86)
http://www.microsoft.com/downloads/thankyou.aspx?familyId=9b2da534-3e03-4391-8a4d-074b9f2bc1bf&displayLang=en
On Fri, Aug 21, 2009 at 3:26 PM, maning
sambale<emmanuel.sambale at gmail.com> wrote:
> I updated the vista machine and tried and tried the sandalone
> installer again. same problem.
> Then I used the osgeo4w installer and I getthe same errow below.
> Any ideas?
> On Fri, Aug 21, 2009 at 11:41 AM, maning
>> apologies i this was alreay discussed, this the first time I had to do it
>> I was able to install the unstable standalone installer by righ-click
>> "run as admin". But I cannot run qgis. It says:
>> "The application has failed to start bec. its side-to-side
>> configuration is incorrect. Please see the application event log for
>> more detail"
>> The event log is:
>> Log Name: Application
>> Source: SideBySide
>> Date: 8/21/2009 6:39:14 PM
>> Event ID: 35
>> Task Category: None
>> Level: Error
>> Keywords: Classic
>> User: N/A
>> Computer: Pedro-PC
>> Description:
>> Activation context generation failed for "C:\Program Files\Quantum GIS
>> Unstable\bin\qgis.exe".Error in manifest or policy file "C:\Program
>> Files\Quantum GIS Unstable\bin\Microsoft.VC90.CRT.MANIFEST" on line 4.
>> Component identity found in manifest does not match the identity of
>> the component requested. Reference is
>> Microsoft.VC90.CRT,processorArchitecture="x86",publicKeyToken="1fc8b3b9a1e18e3b",type="win32",version="9.0.21022.8".
>> Definition is Microsoft.VC90.CRT,processorArchitecture="x86",publicKeyToken="1fc8b3b9a1e18e3b",type="win32",version="9.0.30729.1".
>> Please use sxstrace.exe for detailed diagnosis.
>> Event Xml:
>> <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
>> <System>
>> <Provider Name="SideBySide" />
>> <EventID Qualifiers="49409">35</EventID>
>> <Level>2</Level>
>> <Task>0</Task>
>> <Keywords>0x80000000000000</Keywords>
>> <TimeCreated SystemTime="2009-08-21T17:39:14.000Z" />
>> <EventRecordID>625</EventRecordID>
>> <Channel>Application</Channel>
>> <Computer>Pedro-PC</Computer>
>> <Security />
>> </System>
>> <EventData>
>> <Data>Microsoft.VC90.CRT,processorArchitecture="x86",publicKeyToken="1fc8b3b9a1e18e3b",type="win32",version="9.0.21022.8"</Data>
>> <Data>Microsoft.VC90.CRT,processorArchitecture="x86",publicKeyToken="1fc8b3b9a1e18e3b",type="win32",version="9.0.30729.1"</Data>
>> <Data>
>> </Data>
>> <Data>
>> </Data>
>> <Data>
>> </Data>
>> <Data>
>> </Data>
>> <Data>
>> </Data>
>> <Data>
>> </Data>
>> <Data>
>> </Data>
>> <Data>
>> </Data>
>> <Data>C:\Program Files\Quantum GIS Unstable\bin\qgis.exe</Data>
>> Unstable\bin\Microsoft.VC90.CRT.MANIFEST</Data>
>> <Data>4</Data>
>> <Data>
>> </Data>
>> <Data>
>> </Data>
>> <Data>
>> </Data>
>> <Data>
>> </Data>
>> <Data>
>> </Data>
>> <Data>
>> </Data>
>> <Data>
>> </Data>
>> </EventData>
>> </Event>
>> I already installed MSVC libraries
>> cheers,
>> maning
>> "Freedom is still the most radical idea of all" -N.Branden
>> wiki: http://esambale.wikispaces.com/
>> blog: http://epsg4253.wordpress.com/
> cheers,
> maning
cheers,
maning
