[Qgis-user] 1.1.0 Unstable - not a valid or recognize raster data source
Darren Norris
doon75 at hotmail.com
Mon Aug 24 03:48:37 PDT 2009
Many thanks for the reply Swapnil,
I haven't been able to find anything reported as bug / issue.
So opened one ....
https://trac.osgeo.org/qgis/ticket/1890
No idea if I put the info in correctly but hope it helps to get this resolved.
Darren
Date: 24 Aug 2009 05:46:42 -0000
From: "swapnil appa chaudhary" <sslan at rediffmail.com>
Subject: Re: [Qgis-user] 1.1.0 Unstable - not a valid or recognized
raster data source
To: <doon75 at hotmail.com>
Cc: qgis-user at lists.osgeo.org
Message-ID:
<1251035815.S.3765.20037.f6mail-145-156.rediffmail.com.1251092802.11420 at webmail.rediffmail.com>
Content-Type: text/plain; charset="iso-8859-1"
Hi Darren,
This problem exist with the standalone version of QGIS Kore and QGIS Pan, both.
This issue has been already discussed for Win Vista and Win XP separately in QGIS forum. Have a look at the following links,
http://forum.qgis.org/viewtopic.php?f=2&t=4761
http://forum.qgis.org/viewtopic.php?f=2&t=4660
It seems can be solved by installing OSGeo installer than standalone. I've tried it and it does work. Well, it ain't the right way though. Raster and vector layers should open in GRASS plugin thr the QGIS. Lets hope it will get fixed in next stable version.
Best,
Swapnil
On Sun, 23 Aug 2009 19:26:55 +0530 wrote
> >Can anyone have a look to see if this is just me? QGIS can't read GRASS
rasters:
OS = Windows vista,
Installed via standalone (internet connection is poor so this is the
only option for me)
GRASS 6.4 -
http://grass.itc.it/grass64/binary/mswindows/native/WinGRASS-6.4.0SVN-r38537-1-Setup.exe
QGIS 1.1.0 - http://download.osgeo.org/qgis/win32/QGIS-1.1.0-0-Setup.exe
When I start, QGIS can't find GRASS (GISBASE), so I manually point it to
"C:\Program Files\QuantumGIS\grass".
Try to load a GRASS raster and now "C:/Users/Darren/Documents/GIS
DataBase/test/PERMANENT/cellhd/comp543" is not a valid or recognized
raster data source".
I had the same issue with QGIS 1.0.2-Kore. Uninstalled QGIS (via control
panel - remove programs) and then installed 1.1.0......
So far everything else seems to be fine (projects open fine, GPS plugin
etc). Any suggestions?
Many thanks,
Darren
