[Qgis-user] manage R behaviour
Carson Farmer carson.farmer at gmail.com
Wed Aug 26 02:10:29 PDT 2009
Hi guys,
Does any of the text show up after you load a layer via Ctrl-L or anything
like that?
What about if you try to save a graphic (this should export a command to the
manageR console)?
Based on the versions of the various software required, I can't see why this
isn't working.
It must be a Windows thing, but unfortunately, I don't have access to a
Windows machine at the moment.
Cheers,
Carson
On Tue, Aug 25, 2009 at 10:12 PM, Alessandro Sarretta <
alessandro.sarretta at inwind.it> wrote:
> Hi Carson,
> same behaviour for me, using QGIS trunk e QGIS 1.1, installed by OSGeo4W in
> Windows XP.
> R2.9.0
> manageR 0.7.2
> qt4-libs 4.5.2-1
> pyqt4 4.5.2-5
> python-rpy2 2.0.3-1
> and congratulations, your plugin is improving really well!
> thanks
> Ale
> Carson Farmer ha scritto:
>  Hi Filip,
>>    Dear all,
>>    I finally got to work manage R plug-in (version 0.7.2 woks, I use
>>    R 2.9.1,
>>    Qgis 1.0.2, Win XP).
>>    But I am confused by its behaviour. The console doesn't return any
>>    results.
>>    I mean, when I type:
>>    $ x<-1
>>    $ y<-2
>>    $ x+y
>>    Nothing is returned, even though the variables x and y exist (they are
>>    listed on the Environment tab).
>>    However, when I load a shape file with Ctrl+L, the console writes
>>    out a
>>    message
>>    "QGIS Vector Layer
>>    Is this a standard behaviour of manage R?
>>  no it is not the standard behaviour... I'm not sure why you aren't
>> getting any output to the console with normal R commands.
>> I haven't testing this plugin on Windows yet, so perhaps I'll give this a
>> try tonight and see if I can get the same behaviour.
>> What versions of Qt and Rpy are you running?
Carson Farmer
National Centre for Geocomputation
John Hume Building,
National University of Ireland, Maynooth,
Maynooth,
Co. Kildare,
Ireland.
www.carsonfarmer.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090826/49b73249/attachment.html>
