R: Re: [Qgis-user] manage R behaviour
alessandro.sarretta at inwind.it alessandro.sarretta at inwind.it
Wed Aug 26 02:52:53 PDT 2009
Hi Carson,
I tried with a simple point layer called "SAMA". Data are loaded correctly, but if I try to use "ls()" or "names(SAMA)" I have no results...
If I instead do plot(SAMA$X) I obtain correctly the plot.
So data are loaded, it seems a problem with the "print" output on the manageR console....
Tell me if I can test something...
thanks
Ale
----Messaggio originale---- Da: carson.farmer at gmail.com Data: 26/08/2009 11.10 A: "Alessandro Sarretta"<alessandro.sarretta at inwind.it> Cc: <qgis-user at lists.osgeo.org> Ogg: Re: [Qgis-user] manage R behaviour  Hi guys,Does any of the text show up after you load a layer via Ctrl-L or anything like that?What about if you try to save a graphic (this should export a command to the manageR console)?Based on the versions of the various software required, I can't see why this isn't working. It must be a Windows thing, but unfortunately, I don't have access to a Windows machine at the moment.Cheers,Carson
On Tue, Aug 25, 2009 at 10:12 PM, Alessandro Sarretta <alessandro.sarretta at inwind.it> wrote:
Hi Carson, same behaviour for me, using QGIS trunk e QGIS 1.1, installed by OSGeo4W in Windows XP. R2.9.0 manageR 0.7.2 qt4-libs 4.5.2-1 pyqt4 4.5.2-5
 python-rpy2 2.0.3-1
and congratulations, your plugin is improving really well!  thanks Ale  Carson Farmer ha scritto:
Hi Filip,      Dear all,    I finally got to work manage R plug-in (version 0.7.2 woks, I use    R 2.9.1,    Qgis 1.0.2, Win XP).    But I am confused by its behaviour. The console doesn't return any    results.    I mean, when I type:     $ x<-1    $ y<-2    $ x+y     Nothing is returned, even though the variables x and y exist (they are    listed on the Environment tab).    However, when I load a shape file with Ctrl+L, the console writes    out a    message    "QGIS Vector Layer    Name: ..." etc.     Is this a standard behaviour of manage R?   no it is not the standard behaviour... I'm not sure why you aren't getting any output to the console with normal R commands. I haven't testing this plugin on Windows yet, so perhaps I'll give this a try tonight and see if I can get the same behaviour.  What versions of Qt and Rpy are you running?
-- Carson FarmerNational Centre for GeocomputationJohn Hume Building,National University of Ireland, Maynooth,Maynooth,Co. Kildare,Ireland. www.carsonfarmer.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090826/8264697c/attachment.html>
