[Qgis-user] QGIS Image Clipper Plugin Available
Bob Bruce Bob.Bruce at pobox.com
Mon Aug 31 06:26:38 PDT 2009
Giovanni:
                 thanks for testing the image clipper and the modified
zoom-to-point. I thing that I have fixed the zoom-to-point, could you
please try that again and let me know how it works. I have edited the
icon in order to distinguish it from the previous icon.
Once I am sure that both plugins work then I will add myself to the
plugin repository list (assuming that I can edit the wiki OK)
     Bob
On 8/31/2009 5:19 AM, Giovanni Manghi wrote:
> Hi,
> thanks for the plugin! it seems to work fine also under linux.
> Could you please consider publish it in the community repository, or ask
> to add your repository among the ones that are available in qgis?
> This way your plugin would reach much more people and you will have
> indeed more feedback from the users.
> Under Linux I'm getting an error while installing the modified zoom to
> point plugin
> "The plugin seems to have been installed but I don't know where.
> Probably the plugin package contained a wrong named directory.
> Please search the list of installed plugins. I'm nearly sure you'll find
> the plugin there, but I just can't determine which of them it is. It
> also means that I won't be able to determine if this plugin is installed
> and inform you about available updates. However the plugin may work.
> Please contact the plugin author and submit this issue."
> thanks in advance
> regards
> -- Giovanni --
> On Sun, 2009-08-30 at 22:05 -0500, Bob Bruce wrote:
>> Hi:
>>       I have a plugin available that people may be interested in testing.
>> This can be used to extract and combine portions of one or more image
>> layers in QGIS. I have only used this on Windows but hopefully it would
>> work OK in Linux also. You can get it and some test data by going to the
>> page: http://www.mappinggeek.ca/QGISPythonPlugins/Bobs-QGIS-plugins.xml
>> . We have been using this plugin a lot at my workplace to extract the
>> useable portions of scanned photography that we have georeferenced using
>> the GDAL Georeferencer plugin.
>> There is also the zoom-to-point plugin that I have tweaked to work
>> better with zoom levels.
>>         Bob Bruce
>> No virus found in this outgoing message. Checked by AVG - www.avg.com Version: 8.5.409 / Virus Database: 270.13.71/2335 - Release Date: 08/30/09 06:36:00
>> _______________________________________________ Qgis-user mailing list Qgis-user at lists.osgeo.org http://lists.osgeo.org/mailman/listinfo/qgis-user
>> No virus found in this incoming message.
>> Version: 8.5.409 / Virus Database: 270.13.72/2337 - Release Date: 08/31/09 05:50:00
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090831/c9fcb144/attachment.html>
