[Qgis-user] Problem with SDA4PP/Linked Statistical Display
Anne Ghisla a.ghisla at gmail.com
Wed Dec 9 05:02:06 PST 2009
On Wed, 2009-12-09 at 14:51 +0200, Volkan Kepoglu wrote:
> On Wed, Dec 9, 2009 at 2:24 PM, Anne Ghisla <a.ghisla at gmail.com>
> wrote:
> On Wed, 2009-12-09 at 04:17 -0800, Volkan Kepoglu wrote:
> > updated with ver. 0.142, could you try that if it is fixed?
> > 1. added loading of rJava package function
> > 2. changed the style of loading of iplot package: first checks the
> > package installed or not
> > and then loads the package but skips to control the package whether
> it
> > is loaded or not,
> > because, most probably, i think that there is a bug for iplots
> > package. even it is loaded, sometimes do not return true.
> > for this reason, i prefered not to control the library whether
> loaded
> > or not.
> Hi Volkan, list,
> sounds like the ade4 load failure for HomeRange_plugin
> http://sourceforge.net/tracker/?func=detail&aid=2830501&group_id=48422&atid=453021
> does the require(iplots) work on R?
> the real problem is that i could not produce the same error in every
> time.
> sometimes it works and sometimes not.
Same for me and users that report the problem. Only thing for ade4, I
encountered it mainly on Windows, and R alone showed no problems. It can
be a rpy2 version issue. Unfortunately, extensive testing has not been
done. Let me know how I can help.
my 2 cents..
Anne
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20091209/dfe0528e/attachment.sig>
