[Qgis-user] Problem with SDA4PP/Linked Statistical Display
Agustin Lobo alobolistas at gmail.com
Wed Dec 9 06:37:35 PST 2009
Sorry I cannot test this further until next weekend.
So far the only difference with the new version is that
I get "a formal complaint" on lacking rJava in a popup window instead of
the list of python errors. But rJava is installed
and running fine as far as I can tell (which is not a lot as
I rarely use rJava).
Thanks for your work.
Agus
Volkan Kepoglu wrote:
> updated with ver. 0.142, could you try that if it is fixed?
> 1. added loading of rJava package function
> 2. changed the style of loading of iplot package: first checks the
> package installed or not
> and then loads the package but skips to control the package whether it
> is loaded or not,
> because, most probably, i think that there is a bug for iplots
> package. even it is loaded, sometimes do not return true.
> for this reason, i prefered not to control the library whether loaded or
> not.
> On Tue, Dec 8, 2009 at 9:30 PM, Agustin Lobo [via OSGeo.org] <[hidden
> email]
> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=4139061&i=0>> wrote:
>     Dear Volkan,
>     Thanks for SDA4PP.
>     When I try to run the Linked Statistical Display in SDA4PP (0.141)
>     (R 2.10)
>     (QGIS 1.3.0 from ubuntu jaunty binaries) I get the following error
>     despite having the package rJava installed (also: note that rJava is
>     not listed among the dependencies):
>     Traceback (most recent call last):
>        File "/home/alobo/.qgis//python/plugins/SDA4PP/sda4pp.py", line
>     163, in
>     doIplotTool
>          d = iplot.IplotTool(self.iface)
>        File "/home/alobo/.qgis//python/plugins/SDA4PP/iplot.py", line
>     64, in __init__
>          self.readInputFile()
>     357, in
>     readInputFile
>          errorChecking = sda4ppLoadRpackage.readLib("iplot")
>        File
>     "/home/alobo/.qgis//python/plugins/SDA4PP/sda4ppLoadRpackage.py", line
>     57, in readLib
>          result += loadIplot(r)
>        File
>     137, in loadIplot
>          if (r.require("iplots")[0]):
>        File
>     "/usr/local/lib/python2.6/dist-packages/rpy2/robjects/__init__.py",
>     line
>     422, in __call__
>          res = super(RFunction, self).__call__(*new_args, **new_kwargs)
>     RRuntimeError: Error: package 'rJava' could not be loaded
>     Thanks,
>     Agus
>     _______________________________________________
>     Qgis-user mailing list
>     [hidden email]
>     <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=4134711&i=0>
>     http://lists.osgeo.org/mailman/listinfo/qgis-user
> Regards,
> Volkan Osman Kepoglu
> PhD Candidate
> GGIT Department in METU,
> http:/ggit.metu.edu.tr <http://ggit.metu.edu.tr>
> View this message in context: Re: [Qgis-user] Problem with SDA4PP/Linked
> Statistical Display
> <http://n2.nabble.com/Problem-with-SDA4PP-Linked-Statistical-Display-tp4134711p4139061.html>
> Sent from the qgis-user mailing list archive
> <http://n2.nabble.com/qgis-user-f2036571.html> at Nabble.com.
