[Qgis-user] projection change
Micha Silver
micha at arava.co.il
Wed Dec 16 06:09:13 PST 2009
ahmettemiz88 at gmail.com wrote:
> hello
> I have difficulty changing map projection from lamber conical to
> geographic ?
> how can I do that ?
> here is the original map's metada:
> name: Lambert Conformal Conic
> proj: lcc
> datum: wgs84
> ellps: wgs84
> lat_1: 40.66666666666666
> lat_2: 43.33333333333334
> lat_0: 0
> lon_0: 34
> x_0: 1000000
> y_0: 0
> no_defs: defined
> I tried with ogr2ogr :
> ogr2ogr -t_srs '+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs'
> -s_srs '+proj=lcc +lat_1=40.66666666 +lat_2=43.333333333 +lat_0=0
> lon_0=34 +x_0=1000000 +y_0=0 +datum=wgs84 +units=meter'
> geohidro_cizgi_adf94.shp hidro_cizgi_adf.shp
I think you might be having trouble with the quoting. Maybe try with
just the EPSG code, i.e.:
ogr2ogr -t_srs EPSG:4326 geohidro_cizgi_adf94.shp hidro_cizgi_adf.shp
Micha
> regards
> Ahmet Temiz
> This mail was received via Mail-SeCure System.
> Qgis-user mailing list
