[Qgis-user] Compile error in qgis1.3.0
S_Larosa at libero.it
Thu Dec 17 01:24:17 PST 2009
I get the following error compiling qgis 1.3.0 in debian / lenny:
[ 63%]
Building CXX object src/providers/grass/CMakeFiles/qgisgrass.
dir/qgsgrassprovider.o
/usr/local/grass-6.4.svn/include/grass/Vect.h: In static
member function ‘static int QgsGrassProvider::openMap(QString, QString,
QString, QString)’:
/usr/local/grass-6.4.svn/include/grass/Vect.h:183: error:
too few arguments to function ‘int Vect_build(Map_info*, FILE*)’
/home/sam/dev/cpp/qgis-1.3.0/src/providers/grass/qgsgrassprovider.cpp:1070:
error: at this point in file
member function ‘bool QgsGrassProvider::closeEdit(bool)’:
svn/include/grass/Vect.h:185: error: too few arguments to function ‘int
Vect_build_partial(Map_info*, int, FILE*)’
/src/providers/grass/qgsgrassprovider.cpp:1567: error: at this point in file
/usr/local/grass-6.4.svn/include/grass/Vect.h:183: error: too few arguments to
/src/providers/grass/qgsgrassprovider.cpp:1568: error: at this point in file
make[2]: *** [src/providers/grass/CMakeFiles/qgisgrass.dir/qgsgrassprovider.o]
Error 1
make[1]: *** [src/providers/grass/CMakeFiles/qgisgrass.dir/all] Error 2
make: *** [all] Error 2
the output of cmake command is as follows:
$ cmake ..
-- Found Proj: /usr/lib/libproj.so
-- Found Expat: /usr/lib/libexpat.so
Using GSL from /usr
-- Found GEOS: /usr/lib/libgeos_c.so
-- Found GDAL:
/usr/local/lib/libgdal.so
-- Found PostgreSQL: /usr/lib/libpq.so
-- Found
GRASS: /usr/local/grass-6.4.svn (6.4.svn)
-- Python libraries found
-- Python
bindings enabled
-- Configuring done
-- Generating done
-- Build files have
been written to: /home/sam/dev/cpp/qgis-1.3.0/build
Any hint?
Thanks!
