[Qgis-user] v1.40 polygon editing in a new layer
Fred LaPlante flaplante at flos-inc.com
Sun Dec 20 07:11:48 PST 2009
Thank you. That did the trick.  Looks like the search radius needs to be
about 1 unit and I had it at 0.1.
I was able to delete a node using the 'delete' key after selection got
me a blue box. And I have been able to drag points or lines around
easily enough, but how do you insert a new node? The 'insert' key
doesn't do it.
Fred LaPlante
Martin Dobias wrote:
> Hi,
> please check in Options > Digitising whether you don't have vertex
> search radius set to zero (or too small tolerance)
> Martin
> On Sun, Dec 20, 2009 at 12:59 AM, Fred LaPlante <flaplante at flos-inc.com> wrote:
>> I am unable to edit nodes in a newly created polygon layer.
>> Using the node tool I can edit polygons in other layers created with ver 1.3
>> and earlier.
>> But after enabling edits on the new layer, and selecting the node tool, no
>> amount of clicking on any node of a new polygon has any effect. Nor am I
>> able to delete a new polygon feature (only effect is to remove the selection
>> highlighting).
>> I am using qGIS r12508M, loaded just a few hours ago. Running under Windows
>> XP svc Pk 3.
>> Install was via OSGeo4W.
>> Fred LaPlante
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
