[Qgis-user] Area Measuring Tool enhancements
Fred LaPlante
flaplante at flos-inc.com
Sun Dec 20 07:22:03 PST 2009
That would work for me.
The Settings|Options|MapTools screen currently allows you to choose
between Feet or Meters. Unfortunately the english system of square
feet|acres|square miles isn't something that is easily converted in you
head.
I suppose a pulldown would let you switch back and forth quickly perhaps
so you could easily compare to some written records. But that would
require more code work from developers than what I proposed.
Fred LaPlante
Andreas Neumann wrote:
> it would even be nicer if the tool would offer a combobox with a unit
> choice. Because you may want to have the result in square meters, even
> if the result is a higher number.
> Andreas
> Fred LaPlante wrote:
>> When the preferred measuring units are set to Feet, the area
>> measuring tool has a limitation for users with parcel sizes we have
>> here in my town. Currently areas of less than 0.01 square miles are
>> shown in square feet and above that switch to square miles with 2
>> decimal places shown.
>> I would like to recommend that area measurements stay in square feet
>> until reaching one acre (43,500sq. ft) and then show acres with one
>> decimal place until reaching 640 acres then switch to square miles
>> with one decimal place.
>> Fred LaPlante
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
