[Qgis-user] qml symbology file to arc* format ?
G. Allegri giohappy at gmail.com
Mon Dec 21 14:17:06 PST 2009
Niether QGis can export sld nor Arc* can import it.
Symbology is still a chaos...
2009/12/21 Agustin Lobo <alobolistas at gmail.com>:
> Thank you all, but I'm needing the other way around: I've generated
> a layer with QGIS, have to export it as shape and want to
> create the arcview legend file (avl ?) or
> the equivalent for arcgis from the qml file.
> Or is it that arc* is able to read the sld format?
> Sorry but I dont use arc* at all
> Anyway, as for now qgis does not write sld either, does it?
> Agus
> Alex Mandel wrote:
>> Paolo Cavallini wrote:
>>> G. Allegri ha scritto:
>>>> I don't think Agus, becasue AFAIK the esri layer files (.lyr) are a
>>>> binary closed format.
>>> Can Arc* export to a (sort of) standard format?
>>> In my view, converging towards a standard one (e.g. sld, with additional
>>> tags as
>>> necessary) would be the way to go, in the long term.
>>> All the best.
>> I have seen an Arc2SLD plugin, I think this is it.
>> http://apps.geoinform.fh-mainz.de/arcmap2sld/ArcMap2SLDConverter_Eng.htm
>> Alex
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
