[Qgis-user] QGIS Generated Color Map Export File
Agustin Lobo
alobolistas at gmail.com
Thu Dec 31 05:36:54 PST 2009
Could anybody explain (or point me to the appropriate doc)
the fields in the color table generated
through Export color map to file in raster properties/Color Map?
# QGIS Generated Color Map Export File
INTERPOLATION:DISCRETE
1.4e-05,0,0,255,255,Color entry 1
0.023047,25,0,230,255,Color entry 2
0.04608,50,0,205,255,Color entry 3
I understand the first value is
the initial value of the class,
then the 3 RGB values,
then a value that I do not understand,
(constant to 255) and a comment.
I'd like to make a little function in R
to generate these color tables, as the
current tool in qgis is too limited.
Thanks
Agus
