[Qgis-user] Projection on-the-fly with raster
Luiz Motta
luizmottanet at hotmail.com
Thu Jan 1 07:26:54 PST 2009
QGis make projection on-the-fly with raster or only vector layers ?
I make all steps to make on-the-fly(OTF) describe in userguide.pdf (7.2 Getting Started).
When i enable OTF in project setting the raster layer hide.
I can confirm the extend image in OTF is correct, because, the tool zoom to layer extend running OK, for this, i used the vector layer with same extend image.
Information about my project/data
1) Versin QGis:0.11-Metis
Code revision 8815
2) Projections2.1) Raster Layer:QGIS SRSID: 2435PostGIS SRID: 29190+proj=utm +zone=20 +south +ellps=aust_SA +units=m +no_defs2.2) Qgis project:QGIS SRSID: 3344PostGIS SRID: 4326+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs
3) Format Raster Layer: GEOTIF
_________________________________________________________________
Mais do que emails! Confira tudo o que Windows Liveā¢ pode oferecer.
http://www.microsoft.com/windows/windowslive/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090101/e508e463/attachment.html>
