[Qgis-user] QgsVectorFileWriter
Carson Farmer
carson.farmer at gmail.com
Wed Jan 21 06:27:27 PST 2009
Cedric,
> Hi list
> in a python plugin im using QgsVectorFileWriter.writeAsShapefile to write a shapefile to the disk.
> The first time I use a certain file name/path (e.g /tmp/foo.shp), it works properly. If I try to rerun the script, it fails saying:
> ERROR 1: /tmp/foo.shp is not a directory.
> It looks like it is not possible to replace an existing shapefile that way. Am I correct? Do I have to manage the files myself (i.e. delete them before writing the new file)? Or is there another way to replace an existing shapefile?
Yes you are correct, you cannot overwrite shapfiles like that... but you
can do the following first:
QgsVectorFileWriter.deleteShapefile( "path/to/the/shapefile/shp" )
Cheers,
Carson
Carson J. Q. Farmer
ISSP Doctoral Fellow
National Centre for Geocomputation (NCG),
Email: Carson.Farmer at gmail.com
Web: http://www.carsonfarmer.com/
http://www.ftools.ca/
