[Qgis-user] No module named qgis.core
Jürgen E. Fischer
jef at norbit.de
Wed Jan 21 08:07:13 PST 2009
Hi Radek,
On Wed, 21. Jan 2009 at 15:04:18 +0100, Rados??aw Pasiok wrote:
> I'm using qgis 1.0.0-4 from _OSGeo4W_ and have difficulties running
> custom python scripts:
> >>> from qgis.core import *
> Traceback (most recent call last):
> File "<pyshell#0>", line 1, in <module>
> ImportError: No module named qgis.core
hm, this is getting annoying. That's the same problem as with some
grass modules.
Every DLL and/or EXE loaded from a path not being
%OSGEO4W_ROOT%\bin, which is depending on ssleay32.dll and/or
libeay32.dll won't work, when you have a different version of those two
DLLS in %WINDIR%\system32. For example this affects everything that is
using GDAL16.DLL, which depends on LIBCURL.DLL, which in turn depends on
the 2 DLLs.
AFAIK Windows searches the directory the DLL (or pyd in this case) was
loaded from first, then system32 and after that everything that is in
PATH.
So the solution is to either update the DLLs in system32. I'm not sure
if that might break other things, which might be depending on the
current version. Frank Warmerdam is currently looking into this.
Or you can copy the 2 DLLs to every directory where affected DLLs/EXEs
live. In this case %OSGEO4W_ROOT%\apps\Python25\lib\site-packages\qgis
But that's obviously just a workaround.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
