[Qgis-user] Graticules
Agustin Lobo Agustin.Lobo at ija.csic.es
Tue Jan 27 23:32:18 PST 2009
Carson,
No way to just upgrade the fTools plugin? Do we have
to re-compile? This would be a problem for windows users.
Agus
Carson Farmer wrote:
> Hi all,
>>>> This is actually almost perfect and I do confirm that works
>>>> in the projection being defined for the project.
>>>> The only improvement would be that once you select "Input Boundary
>>>> Layer" you should get the actual values written  in the X,Y fields
>>>> of "Input Coordinates". In this way, the user could then select "Input
>>>> coordinates" to slightly modify the values (you normally want
>>>> the grid at rounded positions).
> This has been added, along with the bug fix for using the manually
> entered extents (the whole setup has been changed a bit). These changes
> are now in svn rev10035.
> Hope that solves your problems...
> Carson
Dr. Agustin Lobo
Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
LLuis Sole Sabaris s/n
08028 Barcelona
Spain
Tel. 34 934095410
Fax. 34 934110012
email: Agustin.Lobo at ija.csic.es
http://www.ija.csic.es/gt/obster
