[Qgis-user] S57 map files
Chris h
chris123 at magma.ca
Sun Jan 18 12:52:01 EST 2009
On Sunday 18 January 2009 11:04:13 Florian El Ahdab wrote:
> So here are my questions:
> - has anyone ever worked with S57 and OGR and/or Qgis?
This discussion came up on the gpsdrive list and i've included the pertinent
parts for you review:
From Hamish Bowman:
For ENC support in GpsDrive it is still my hope that libS52
could be used to render the data, in a similar way as Mapnik
is rendering OSM data now.
see
http://apps.sourceforge.net/mediawiki/gpsdrive/index.php?title=Marine_Howto
(please help improve the wiki page!)
http://grass.osgeo.org/wiki/BSB_data
http://grass.osgeo.org/wiki/S-57_data#libS52
http://openev.cvs.sourceforge.net/openev/contrib/S52/
the very tricky bit is choosing which layers to include. the S-52
gives recommendations of which features to display based on map
scale class, I'd say reuse those. But you would have to enter
that data by hand. If someone provides a list of layernames
per scale band, I might do the rest.
response: me, requesting a tutorial to review the material.
response: Hamish
see SCAMAX and SCAMIN entries in the libS52 CVS file doc/att.txt,
for each token these control which map scales (e.g. 1:25,000-1:100,000)
the feature should be rendered.
and read through the remarks in S52CS.c in the libS52 source
// S52CS.c : Conditional Symbologie procedure 3.2 (CS)
(ignore the code, just look at the comments...)
and the IHO PDF spec docs,
http://grass.osgeo.org/wiki/S-57_data#GRASS_S-52_interface_for_rendering_S-57_data
and you may see why I defer :). It's all there & coded, but a bit daunting
to me.
My idea is a little wrapper C program around S52CS.c to export tokens
based on a list of scales would help us make a table which we could use
in developing the list of layers for the WMS request.
since qgis is used extensively in preparing maps for gpsdrive and there is
significant interest wrt marine navigation where most charts are S-57 vectors
the long term goal (very long term) is to move toward a plugin for qgis to
manipulate the data in order to make it available to gpsdrive. However its a
bit of a challenge as you can see, I'm not a developer, rather just a listee
with sailboat so I keep interested in this stuff.
> - I believe Qgis doesn't use the S57 sublayers and that's why nothing gets
> displayed. Is there any chance that I am right? If I am right,
Your most likely correct.
> I would like
> to help with the implementation for this kind of problem. Can anyone in the
> dev team give me directions on where to begin (I have spent some time in
> the source and API of both Qgis and GDAL and feel I can contribute here...)
Perhaps a good start would be reviewing the submitted material above and then
following the directions and advice of the qgis development team.
Best of luck
/ch
