[Qgis-user] PostGIS manager v0.5
Micha Silver micha at arava.co.il
Wed Jul 8 23:02:56 PDT 2009
Hello Martin:
A few more points you might take into consideration:
1- The "VACUUM ANALYZE" warning appears also for views. That's probably
unnecessary.
2- To get the plugin working on windows, the psycopg2 library must be
installed. That's available when using the OSGeo4W installer, thru the
"Advanced" option. It's worth mentioning this (somewhere...).
3- Is it possible to  maintain the state of the Table of Contents list
of schemas and tables from session to session? It's a minor point, but
with a long list of tables, this might add a bit to usability.
On the whole, this plugin is a substantial boost for QGIS-PostGIS setups.
Thanks,
Micha
Martin Dobias wrote:
> Hi all,
> I'd like to announce new version of PostGIS Manager - already in the
> repositories (both in mine and in contributed plugins at pyqgis.org):
> - shows triggers and rules, able to delete or enable/disable them
> - faster GUI as it loads only content for current tab (and not all of
> them as before)
> - geometry processing - allows you to do area/length calculation and
> (optionally) set a trigger that updates the field on inserts and
> updates
> - table versioning (experimental) - modifies a table so it stores all
> history of the changes
> - various updates and bug fixes I've incorporated from the feedback I've got
> Any feedback is welcome as usual :)
> Martin
> Qgis-user mailing list
> This mail was received via Mail-SeCure System.
