[Qgis-user] Brochure draft for QGIS 1.1
stefaan dondeyne stefaan_dondeyne at yahoo.co.uk
Tue Jul 14 12:26:06 PDT 2009
Hi Anita,
great initiative
- I like to underscribe the suggestion for some sans-serif fonts and not putting the version in the title
- I would also like to suggest on your very first screen capture to use an image from a "stable" version; seeing "(unstable)" on the very first image may not be the best publicity
Any way - great job - congrates,
Stefaan
_________________________________________________
Stefaan Dondeyne (PhD)
Natural Resources Management & Research
Bloemenlaan 11 - 3001 Leuven - Belgium
GSM +32 476 61 90 65 (Belgium)
Cell 82 32 86 854 (Mozambique)
http://www.actf.gov.mz/reserva_chimanimani.html
http://www.mozambiqueflora.com/index.php
http://micaia.org/centre/micaia_family.html
--- On Tue, 14/7/09, Andreas Neumann <a.neumann at carto.net> wrote:
Subject: Re: [Qgis-user] Brochure draft for QGIS 1.1
To: "Mailing Lists" <lists at linfiniti.com>
Cc: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>, "Anita Graser" <anitagraser at gmx.at>
Date: Tuesday, 14 July, 2009, 9:08 PM
Thank you for your contribution, Anita!
I also wanted to suggest the use of sans-serif fonts. I would even go as
far as only using sans-serif - also for the titles. But of course this
is only my personal taste.
I personally like the MS Trebuchet, the Myriad and the Frutiger fonts.
Let me know if you need one of those fonts to try them out.
As far as Windows is concerned: I was successfully using QGIS on Windows
2000, since my employer just recently switched from 2000 to XP. It ran
just fine on 2000 to my surprise. So yes, I would make it "Windows"
without a particular version.
Regarding the vector format support I would also add SpatiaLite - it is
one of the first GIS supporting this useful alternative. I see there is
still room on the line before the ... ;-)
Maybe one could consider changing the text "Compile a map for printing
using the print composer" into "Compile a map layout using the print
composer" to avoid using printing twice and highlight the layout issue.
Best regards,
Andreas
Mailing Lists wrote:
> Hi Anita
> Great improvements! A couple more small comments :-)
> - Do we need to show the version number in the title? If we leave it
> out it will require less maintenance to keep the document current.
> - Do you have verdana / vermana or arial font on your system? The sans
> serif font is definately better but now for me the document is looking
> a little horizontally squashed with the one that you are using...
> - in the final block with urls, could you bold the 'header' words and
> colons on the left to visually separate the item name from the item
> details?
> - I suggest to remove the "- ..." entry from the plugins list and / or
> change it to read  "- and many others"
> - In platform support I guess we should change "windows xp" to
> "windows" since AFAIK it will work on new (and older probably)
> versions of windows too.
> Regards
> Tim
> On Tue, Jul 14, 2009 at 10:34 AM, Anita Graser<anitagraser at gmx.at> wrote:
>> Hi Tim!
>> I followed your suggestions and uploaded a new version:
>> http://www.students.oamk.fi/~t5jama01/div/qgis_brochure_new_v1.pdf
>> On screen sans serif fonts definitely look better. I'll try to get the
>> brochures printed the next days and compare those results.
>> Regards,
>> Anita
>> Am 14.07.2009, 08:13 Uhr, schrieb Mailing Lists <lists at linfiniti.com>:
>>> Hi Anita
>>> Great to see you refreshing the brochure. I have various comments /
>>> suggestions:
>>> - In the heading I suggest to remove the third line of links (which
>>> are repeated at the end of the document) and instead make the second
>>> line read: "Open Source Geographical Information System -
>>> http://qgis.org"
>>> - I also suggest to center the second line under the part after the Q
>>> logo of QGIS.
>>> - What about moving the screenshot on page 1 right to the start so
>>> that the first thing you see when you see the doc is the QGIS title
>>> and a screenie, and then the text that follows?
>>> - could you use a sans serif font for the non heading text? Generally
>>> I find serif fonts look a bit old fashioned and not as 'clean'. It
>>> would be interesting to see how it looks anyway so that we can compare
>>> against the current serif version you have made.
>>> - change "Project Administrator" to "Project Chairman"
>>> - change the link in the box at the end of the document for qgis home
>>> page to http://qgis.org
>>> Great work Anita!
>>> Regards
>>> Tim
>>> On Mon, Jul 13, 2009 at 8:19 PM, Anita Graser<anitagraser at gmx.at> wrote:
>>>> Hi all!
>>>> For QGIS1.1, I redesigned the current brochure and added new Screenshots
>>>> (including a shot of fTools). I've been working with Scribus.
>>>> A pdf of the brochure can be downloaded here:
>>>> http://www.students.oamk.fi/~t5jama01/div/qgis_brochure_new.pdf
>>>> I would love to get feedback on how you think the brochure and other QGIS
>>>> materials could be improved. Do you have wishes for additional
>>>> presentation
>>>> material? We can collect ideas in the wiki:
>>>> http://www.qgis.org/wiki/Community_Resources#Press_Centre
>>>> Best wishes,
>>>> Anita
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090714/4a018f11/attachment.html>
