[Qgis-user] "Freehand" raster georeferencing
Maxim Dubinin sim at gis-lab.info
Mon Jul 20 12:35:03 PDT 2009
interesting idea, as far as I know there are no plugins that can do that yet.
However, if you have something to reference you source map to, than you can use
usual georeferencing approach. Simply in this case, you'll have to
collect GCPs from source map to georeferenced map, but not enter
the known coordinates directly. This will be less interactive equivalent of
"freehand" approach.
Maxim
MG> Have got some raster maps. But there are no points with known
MG> coordinates on this maps. I want to do some "georeferencing" for this
MG> rasters, and only way to do it, is to move/scale/rotate as long, as they
MG> didn't fit to the other maps with known coordinates. Just something like
MG> "freehand georeferencing". I know that there is lack of accuracy, but in
MG> some cases this is better that none. So, anybody works on something that
MG> can do it? Plugin? Feature? Or maybe, I should add a ticket to trac.
