[Qgis-user] WMS Problems with the Windows builds
Maxim Dubinin
sim at gis-lab.info
Tue Jul 14 16:00:51 EDT 2009
is it related to this bug?
http://trac.osgeo.org/osgeo4w/ticket/67
Maxim
AN> For the sake of helping others that may run into the same problem:
AN> the problem could be solved with the help of Jürgen and Marco.
AN> The standard OSGeo installation path is on C:\OSGeo - I installed under
AN> C:\Programme\OSGeo, because our IT services told me to do so. As a
AN> result, qt couldn't find it's image plugins. Jürgen could solve the
AN> issue by setting the environment variable QT_PLUGIN_PATH:
AN> set QT_PLUGIN_PATH=%OSGEO4W_ROOT%\apps\Qt4\plugins
AN> the batch file could be stored in %OSGEO4W_ROOT%\etc\ini\qt4.bat
AN> After that jpeg images can be loaded in the print composer, WMS requests
AN> and in customized GUI elements of plugins.
AN> Jürgen fixed the OSGeo installer to handle such cases.
AN> Thanks!
AN> Andreas
