[Qgis-user] raster catalog: qtsql?
John C. Tull
john.tull at wildnevada.org
Mon Jun 15 11:37:04 PDT 2009
Maybe loosely related, but I have a problem on OS X where uic is not
loading. I believe this is a standard component of PyQt, and it shows
as being installed in PyQt, so I'm not sure what is happening here:
The plugin is broken. Python said:
cannot import name uic
Thanks,
John
On Jun 14, 2009, at 11:43 PM, Andreas Neumann wrote:
> You need both.
> libqt4-sql is for C++ and also the foundation for other script
> bindings
> like python (correct me if I'm wrong).
> python-qt4 are the python bindings for Qt4, it includes qtsql
> bindings.
> You probably also need one of the following packages:
> libqt4-sql-psql (Postgres support)
> libqt4-sql-sqlite (SQlite 3 support)
> or any other db you want to support.
> Andreas
> On Mon, June 15, 2009 8:17 am, Agustin Lobo wrote:
>> I've tried to install (on qgis 1.1.0) the raster catalog plugin and
>> I 'm
>> told
>> that Qtsql is required, but which package exactly? According to
>> Synaptic I have python-qt4 4.3.3.2 and libqt4-sql 4.4.0
>> Thanks
>> Agus
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Andreas Neumann
> http://www.carto.net/neumann/
> http://www.svgopen.org/
