[Qgis-user] raster catalog: qtsql?
Alex Mandel tech_dev at wildintellect.com
Mon Jun 15 19:00:00 PDT 2009
Hmm, maybe they aren't included in python-qt4 Ubuntu seems to have a
python-qt4-sql package, try that.
Alex
Agustin Lobo wrote:
> Thanks,
> I meant that I already had
> python-qt4 4.3.3.2
> libqt4-sql 4.4.0
> installed.
> After your message, I installed
> libqt4-sql-psql
> libqt4-sql-sqlite
> libqt4-sql-odb
> but still was geting the same message in qgis:
> "The plugin depends on some components missing on your system. You need
> to install the following Python module in order to enable it: QtSql"
> I've now installed
> python-qt4-sql
> and finally could install the plugin. Nevertheless, after restart, the
> plugin is greyed as incompatible in the plugin manager.
> I'm using Qgis 1.1.0 Pan Uunstable)
> Thanks
> Agus
> Andreas Neumann wrote:
>> You need both.
>> libqt4-sql is for C++ and also the foundation for other script bindings
>> like python (correct me if I'm wrong).
>> python-qt4 are the python bindings for Qt4, it includes qtsql bindings.
>> You probably also need one of the following packages:
>> libqt4-sql-psql (Postgres support)
>> libqt4-sql-sqlite (SQlite 3 support)
>> or any other db you want to support.
>> Andreas
>> On Mon, June 15, 2009 8:17 am, Agustin Lobo wrote:
>>> I've tried to install (on qgis 1.1.0) the raster catalog plugin and I 'm
>>> told
>>> that Qtsql is required, but which package exactly? According to
>>> Synaptic I have python-qt4 4.3.3.2 and libqt4-sql 4.4.0
>>> Thanks
>>> Agus
