[Qgis-user] Plugin.xml troubles
Sampson, David
David.Sampson at NRCan-RNCan.gc.ca
Tue Jun 16 10:25:38 PDT 2009
I plopped mine in the htdocs dir of OSGEO4W and it worked....
After you log out of SourceForge or leave the project page for a length of time the direct download links are forwarded to their HTML interface instead of a direct download.
I am not sure if there is a way around this or not. I think it is to drive advertsiing.
Might be able to drop them in a common HTDOCS directory on SF to try that.
Cheers
> -----Original Message-----
> From: qgis-user-bounces at lists.osgeo.org
> [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Borys Jurgiel
> Sent: Tuesday, June 16, 2009 12:48
> To: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] Plugin.xml troubles
> Tuesday 16 of June 2009 17:59:08 Sampson, David napisaĆ(a):
> > For the record, this is the error that is returned from qgis
> > Error reading repository: Qgis Community plugin Repository Couldn't
> > parse output from the repository
> Hi, this error is a bit mysterious. If I open the file with
> Kate and save it as a new file, it starts to work. However I
> can't see any problems with encoding nor EOL chars... I'll
> look at this issue tonight.
> Qgis-user mailing list
