[Qgis-user] Segmentation fault
Siki Zoltan siki at agt.bme.hu
Mon Jun 22 12:45:52 PDT 2009
Hi Christy,
Your tipp solves my "segmentation fault" trouble on Fedora 9.
Thanks
Zoltan
On Mon, 22 Jun 2009, Christy Nieman wrote:
> Did you happen to have a Qt update recently?  This caused grief for me for
> quite a while:
> http://forum.qgis.org/viewtopic.php?f=3&t=4335#p8204
> Just a thought.
> Christy
> Evert Groenewald wrote:
>> I have the latest Qgis installed, version 1.1.0-2.11 from the openSuse
>> 11.1 x86_64  repos. When starting qgis the splash screen appears and
>> then nothing. When starting from the command line with the command
>> "qgis" it simple states "Segmentation  fault" and stops.
>> evert at linux-inzk:~> qgis
>> Segmentation fault
>> I've removed qgis and its configuration files, reinstalled all with the
>> same results. Could it have something to do with the python version?
>> Installed  version is python 2.6.0-2.21.1 . I know that at some point a
>> python upgrade was incompatible with the qgis installation on openSuse
>> 11.1  .
>> Will appreciate any help.
>> Thanks
>> evert
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
