[Qgis-user] help for GRASS modules: *.region.*
Paolo Cavallini cavallini at faunalia.it
Mon Jun 22 23:11:57 PDT 2009
Hi Nikos.
Just a couple of notes:
Nikos Alexandris ha scritto:
> * The "..." button does not offer the selection of multiple
> raster/vector maps in the g.region.multiple.* tools
This should be fixed in recent trunk - can you check?
> Descriptions
> * Most tools just show the "whole" manual as taken from GRASS
> * Most tools do just a single thing
> * I suggest to keep only single-definitions/sentences as descriptions
> for each tool
The descriptions are the manpages of GRASS, therefore they contain all
the options. This can be confusing, but allows the user to re-run the
command from the built-in terminal using the full power of grass.
Cutting the man to have only the functions used for a particular module
is a lot of dumb work, difficult to keep aligned with upstream changes.
All the best.
Paolo Cavallini: http://www.faunalia.it/pc
