[Qgis-user] raster catalog: qtsql?
John C. Tull
john.tull at wildnevada.org
Tue Jun 23 10:02:04 PDT 2009
Apparently this has not been addressed. Can anyone confirm if there
has been progress made on this issue? This would be a useful plugin if
I understand correctly what it is supposed to do.
Regards,
John
On Jun 15, 2009, at 11:16 PM, Agustin Lobo wrote:
> Alex,
> I already had installed both python-qt4 and python-qt4-sql,
> I can install the plugin with no error messages, but it shows
> up as incompatible in the plugin manager once
> installed and qgis restarted.
> Agus
> (is the author JJL listening this list? Could not find any message
> from him/her
> and cannot cc)
> Alex Mandel wrote:
>> Hmm, maybe they aren't included in python-qt4 Ubuntu seems to have a
>> python-qt4-sql package, try that.
>> Alex
>> Agustin Lobo wrote:
>>> Thanks,
>>> I meant that I already had
>>> python-qt4 4.3.3.2
>>> libqt4-sql 4.4.0
>>> installed.
>>> After your message, I installed
>>> libqt4-sql-psql
>>> libqt4-sql-sqlite
>>> libqt4-sql-odb
>>> but still was geting the same message in qgis:
>>> "The plugin depends on some components missing on your system. You
>>> need
>>> to install the following Python module in order to enable it: QtSql"
>>> I've now installed
>>> python-qt4-sql
>>> and finally could install the plugin. Nevertheless, after restart,
>>> the
>>> plugin is greyed as incompatible in the plugin manager.
>>> I'm using Qgis 1.1.0 Pan Uunstable)
>>> Thanks
>>> Agus
>>> Andreas Neumann wrote:
>>>> You need both.
>>>> libqt4-sql is for C++ and also the foundation for other script
>>>> bindings
>>>> like python (correct me if I'm wrong).
>>>> python-qt4 are the python bindings for Qt4, it includes qtsql
>>>> bindings.
>>>> You probably also need one of the following packages:
>>>> libqt4-sql-psql (Postgres support)
>>>> libqt4-sql-sqlite (SQlite 3 support)
>>>> or any other db you want to support.
>>>> Andreas
>>>> On Mon, June 15, 2009 8:17 am, Agustin Lobo wrote:
>>>>> I've tried to install (on qgis 1.1.0) the raster catalog plugin
>>>>> and I 'm
>>>>> told
>>>>> that Qtsql is required, but which package exactly? According to
>>>>> Synaptic I have python-qt4 4.3.3.2 and libqt4-sql 4.4.0
>>>>> Thanks
>>>>> Agus
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> <alobolistas.vcf>_______________________________________________
