[Qgis-user] Importing USGS DEMs
Brook Milligan brook at biology.nmsu.edu
Sat Jun 27 15:01:59 PDT 2009
John C. Tull writes:
 > Likely, you need to set the color options in the layer properties. I'm
 > not too familiar with how you do that correctly, but maybe someone
 > else will suggest the right steps.
Yes, it seems that I can display the data using the 'pseudocolor' or
'freak out' (what exactly is that?) color maps.  The 'grayscale' color
map just gives a solid gray rectangle, whereas the 'colormap' option
gives just a blank background.  I would prefer a simple grayscale
image.
Any suggestions on how to accomplish this with qgis 1.0.2 compiled
from source?
Thanks for your help.
Cheers,
Brook
