[Qgis-user] Public Repository for plugins...
Sampson, David David.Sampson at NRCan-RNCan.gc.ca
Tue Jun 16 09:18:37 EDT 2009
For a community plugin repo I assume that multiple authors might be involved in the development of a plugin
For the element... <author_name>Someone</author_name>
Can this be a comman separated value.
I am thinking of automaticaly generating this from an AUTHORS.txt file
Also, is there an e-mail optio we can add or what about a URL to an AUTHORS file?
Cheers
> -----Original Message-----
> From: qgis-user-bounces at lists.osgeo.org
> [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Borys Jurgiel
> Sent: Monday, June 15, 2009 19:15
> To: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] Public Repository for plugins...
> Monday 08 of June 2009 22:03:47 Sampson, David napisał(a):
> > Maybe those that are interested can have a little thread
> and come up
> > with a temp solutions while the ducks line up...
> > I would propose sourceforge as that is what I know and I
> already help
> > admin a project on sourceforge.
> > I would say if we can get three plugin groups working
> together that is
> > a good start.
> > Any takers?
> This is good idea.
> The present state of multi-instance plugins I've tried to
> explain in my previous post. In general, you can add to your
> repository two instances of the same
> plugin:
>   <pyqgis_plugin version="0.1" name="Foo Plugin" >
>     <description>Some description</description>
>     <homepage>http://foo</homepage>
>     <qgis_minimum_version>1.0</qgis_minimum_version>
>     <file_name>foo.zip</file_name>
>     <download_url>http://some_url/some_dir/foo.zip</download_url>
>   </pyqgis_plugin>
>   <pyqgis_plugin version="0.2-beta" name="Foo Plugin" >
>     <download_url>http://some_url/another_dir/foo.zip</download_url>
>     <experimental>true</experimental>
>   </pyqgis_plugin>
> Note that there are two plugins foo.zip. The latter one has
> higher version number, but is marked with the optional tag
> <experimental>. It means, that will be chosen as the 'best
> available' for all users allowing experimental plugins.
> For those, who didn't enable experimental plugins, the former
> plugin will be chosen. Similarly, you can publish one
> instance for QGIS>=1.0 and another one for QGIS >=1.1 Just
> remember to give a higher version for the latter one and
> installer choose the highest one if the >=1.1 requirement is
> fulfilled.
> Note that both files are named foo.zip, so you can't put them
> together to the main contributed repository, as they all are
> stored in one directory there. But you can use the suffix I
> mentioned in my previous mail:
> foo.zip      ----> containing the directory "foo"
> foo.beta.zip ----> containing the same directory "foo"
> Oh, the main repository doesn't handle the 'experimental' tag
> yet, AFAIK? But I hope it will be implemented soon.
> Note that there are only two levels of stability:
> <experimental> or not. It has been discussed whether we need
> more and realized that just don't. Please remember that there
> are so many authors with different opinions and different
> willingness to keep metadata accurate ;) that I found keeping
> it as simple as possible reallyu essential :)
> Qgis-user mailing list
