[Qgis-user] coordinate system of a raster layer
Stefanie Tellex stefie10 at media.mit.edu
Mon Mar 2 05:00:53 PST 2009
Hi Peter,
I am trying to define a coordinate system.  I have an image that is just
an image, with no intrinsic coordinate system.  Then I have regions of
the image encoded as polygons in a vector layer in pixel space.  (0,0 is
the upper left hand corner of the image, 960,960 is the lower right hand
corner.)  I want to see the polygons overlayed on the image in QGIS, and
draw new polygons to indicate new regions in the image.
As a hack, I added this method to QgsRasterLayer that sets
mGeoTransform, and call it after loading the raster layer.  That works
to move the raster layer around to align with the vector layer>. (The
full patch is attached.)
+   void setGeoTransform(QList<double> transform) {
+      for (int i = 0; i < 6; i++) {
+	mGeoTransform[i] = transform[i];
+      closeDataset();
+      readFile( source() );
That works to align the image with the vector layer, but now I noticed
that the vector layer is flipped about the Y axis.  I could probably use
setGeoTransform to flip the raster layer so they align, but then the
image would be upsidedown.  What I really want to do is tell the
QgsVectorLayer to use a coordinate system that is reflected across the
Y-axis.
Thanks!
Stefanie
Peter Ersts pisze:
> Hi Stefanie,
> Are you just trying to define a coordinate system or are you trying to
> change one? It kind of sounds like you are actually trying to reproject
> your raster layer on the fly which is not currently supported.
> Right now QGIS is heavily reliant on GDAL for most of the raster
> capabilities and all of the functionality in QgsRasterLayer except the
> pyramid building is read only.
> -pete
> Stefanie Tellex wrote:
>> Hi,
>> I want to change the coordinate system of a raster layer, to control
>> where it is rendered relative to a vector layer.
>> I'm constructing a raster layer (from python) like this:
>> rasterLayer = QgsRasterLayer("resources/21.kitchen.png")
>> It displays, it looks like at the right scale, but at the wrong place.
>> It looks like I want to set mGeoTransform in QgsRasterLayer but I
>> don't see a setter for it.  Should I submit a patch to add one or is
>> there some other way?
>> Thanks!
>> Stefanie
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090302/f5166351/attachment.ksh>
