[Qgis-user] Setting a line's length attribute
Andreas Neumann a.neumann at carto.net
Tue Mar 3 11:37:44 PST 2009
Hi Matej,
QGIS does not yet have a field calculator or a similar mechanism. But
since your data is in Postgis already, it is very easy to do it with
Postgis and SQL:
UPDATE yourschema.yourtable SET LineLength = ST_Length(the_geom);
You can even set a row-level trigger so that the length gets
automatically updated if a geometry changed. Please let me know if you
are interested in the trigger thing.
Andreas
Matej wrote:
> Hello,
> I have a PostGIS table which has an attribute "length". I would like
> to have calculated length of every particular segment (the information
> that is printed when I click on the Identify Features and then select
> some line segment) to be somehow "set" into the field length
> automatically. In MapInfo, this can be achieved by Update column and
> then setting the ObjectLen to the appropriate field.
> How can this be done in QGIS?
> Thanks a lot!
> Matej
> matej at matnet.net <mailto:matej at matnet.net>
> Qgis-user mailing list
