[Qgis-user] PostGIS layers invalid in 1.0.1
Bernhard Ströbl bernhard.stroebl at jena.de
Tue Mar 10 01:13:56 PDT 2009
I have no problems loading PostGIS data with QGIS 1.0.1 installed on XP
with OSGeo-Installer (no oids).
Can you display _any_ PostGIS-layer? If not maybe it is a connection
problem? Can you make a select from the same machine on the particular
table using the same DB access (username, passsword)?
regards
Bernhard
Standaert Arnout schrieb:
> Hi Paolo and list,
> Unfortunately that does not make it work over here :-) Even with OIDs I get an error message about the query.
> Should I send this to the dev mailing list, maybe? Surely there has to be someone who knows more about what's going on behind the QGis scene here.
> Kind regards,
> arnout
>> -----Original Message-----
>> From: Paolo Cavallini [mailto:cavallini at faunalia.it]
>> Sent: maandag 9 maart 2009 15:22
>> To: Standaert Arnout
>> Cc: 'qgis-user at lists.osgeo.org'
>> Subject: Re: [Qgis-user] PostGIS layers invalid in 1.0.1
>> Standaert Arnout ha scritto:
>>> Hi list,
>>> I've been using Qgis in the 1.0 previews without problems.
>> Now, with
>>> the 1.0.1 release via the online installer (on WinXP), my PostGIS
>>> layers do not load anymore. Nothing in the database
>> changed, so this
>>> is probably a QGis issue.
>> No issues here (but we have OIDs).
>> pc
>> Paolo Cavallini: http://www.faunalia.it/pc
> This e-mail, any attachments and the information it contains are confidential and meant only for the use of the addressee(s) only.  Access to this e-mail by anyone other than the addressee(s) is unauthorized.  If you are not the intended addressee (or responsible for delivery of the message to such person), you may not use, copy, distribute or deliver to anyone this message (or any part of its contents) or take any action in reliance on it.  In such case, you should destroy this message and notify the sender immediately.  If you have received this e-mail in error, please notify us immediately by e-mail or telephone and delete the e-mail from any computer.
> All reasonable precautions have been taken to ensure no viruses are present in this e-mail and its attachments.  As our company cannot accept responsibility for any loss or damage arising from the use of this e-mail or attachments we recommend that you subject these to your virus checking procedures prior to use.
> Qgis-user mailing list
> ________ Information from NOD32 ________
> This message was checked by NOD32 Antivirus System for Linux Mail Server.
> http://www.nod32.com
