[Qgis-user] length...
Carson Farmer carson.farmer at gmail.com
Thu Mar 12 10:41:37 PDT 2009
T,
To get the column length, you can use the export/add geometry function
in fTools, which will create a copy of the dataset (as a shapefile) with
an additional length field (or it will populated the length field if it
already exists). From this you can use the compute basic statistics
function to get the sum of the field...
Hopefully that's what you are looking for?
Carson
> HI everybody
> i hope someone can help me with this:
> in a poly-line vector layer, which is obviously built of several
> festures, how can i add a column of LENGTH to the attribute table?
> then how can i SUM all of it?
> THNX
> T
> Qgis-user mailing list
Carson J. Q. Farmer
ISSP Doctoral Fellow
National Centre for Geocomputation (NCG),
Email: Carson.Farmer at gmail.com
Web:   http://www.carsonfarmer.com/
       http://www.ftools.ca/
