AW: Re: [Qgis-user] New PostGIS SQL Query Editor Plugin
John C. Tull john.tull at wildnevada.org
Thu Mar 12 14:07:33 PDT 2009
I missed the pgsql2shp error when I ran this earlier (I had a path
addition to make as that is in a non-standard location). Now I see
your point for this, and it is a good idea. Thanks for the
contribution and explanation. I'm sure I will be using it.
John
On Mar 12, 2009, at 1:25 PM, Düster Horst wrote:
> John,
> I created the plugin due to the lack of possibility to visualize
> PostGIS SQL Queries with resultant tables containing geometry
> columns. In principle it should have a similar behaviour like the
> PgAdmin3 SQL Editor. With the difference that the new plugin creates
> a geographical view at the result too.
> Mini docmentation:
> 1. You have to define a PostGIS connection with the PostGIS Connector
> 2. When you start the plugin for the first time, it will ask for a
> temp-path because it has to store the resultant shape files into a
> directory. For further sessions this directory will be used until
> you change it with the ... button
> 3. select the former defined PostGIS connectin
> 4. Under the assumption you have a PostGIS Table called example with
> one geometry-column you can use the plugin to execute the following
> query:
> select * from example
> when you hit the execute button or alternatively F5 the query is
> executed and it produces a shape-file with the query result. But my
> simple example doesn't make much sense. The use of the plugin makes
> sense when you develop complex queries with joins, aggregations,
> filter, functions etc. In this case you are able to develop your
> query and to view the result directly and very easy. I think it is
> very helpful.
> >Also, the plugin asks for a temporary directory to store files in,
> but it seems that you need a permanent directory to work from. This
> is where I am confused. Is this meant to perform queries on
> >existing postgis tables, or is it meant to query a shapefile and
> then load it into postgis? If the former, how does it improve on
> adding a postgis layer and performing the query there?
> In many cases when you develop spatial queries it is helpful to see
> the result directly. Thus you have to save the query-result
> temporarily many times until you have finished the development
> process. Than you can take your query and make a view from it into
> the database, which you can load directly from PostGIS via Postgres
> connector of course. The idea is to have a developement tool it is
> not the idea to create persistent queries. If you like to save your
> temporary query result to a non temporary place, please use the QGIS
> save as shapefile command.
> I hope that the intension and the use of the plugin will be a little
> more precised.
> Regrads
> Horst
> Dr. Horst Düster
> Stv. Amtschef / GIS-Koordinator
> Kanton Solothurn
> Bau- und Justizdepartement
> Amt für Geoinformation
> SO!GIS Koordination
> Rötistrasse 4
> CH-4501 Solothurn
> Telefon ++41(0)32 627 25 32
> Telefax ++41(0)32 627 22 14
> mailto:horst.duester at bd.so.ch
> http://www.agi.so.ch
> -----Ursprüngliche Nachricht-----
> Von: John C. Tull [mailto:john.tull at wildnevada.org]
> Gesendet am: Donnerstag, 12. März 2009 17:47
> An: Düster Horst
> Cc: qgis-user
> Betreff: Re: [Qgis-user] New PostGIS SQL Query Editor Plugin
> Düster,
> Do you have any documentation on how to use this? I gave it a go
> this morning, but a simple query statement did not work. What would
> be a snippet that would work in the query editor given that one has
> a table called "example" in a database called postgis with public
> schema on a local server?
> is where I am confused. Is this meant to perform queries on existing
> postgis tables, or is it meant to query a shapefile and then load it
> into postgis? If the former, how does it improve on adding a postgis
> Cheers,
> John
> On Mar 12, 2009, at 1:36 AM, Düster Horst wrote:
>> I just uploaded the new PostGIS SQL Query Editor Plugin to the QGIS
>> User-Contributed Python Plugin Repository. The aim of the plugin is
>> to edit and perform any spatial PostGIS query from an editor
>> environment. After successful execution of a query the result will
>> be loaded from shape file to MapCanvas. The plugin works provided
>> that pgsql2shp is installed and the path to pgsql2shp is defined in
>> the system PATH environment.
>> I hope that the plugin will be helpful for you. I'm looking forward
>> for any comment.
>> Regards
>> Dr. Horst Düster
>> Kanton Solothurn
>> SO!GIS Koordination
>> Rötistrasse 4
>> CH-4501 Solothurn
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090312/b60ad786/attachment.html>
