[Qgis-user] length...
Lionel Roubeyrie lroubeyrie at limair.asso.fr
Fri Mar 13 02:35:15 PDT 2009
The ET GeoWizard toolbox for ArcView puts geometry columns in a new
shapefile... certainly safier!
Le vendredi 13 mars 2009 à 11:05 +0200, Micha Silver a écrit :
> Carson Farmer wrote:
> > T,
> > To get the column length, you can use the export/add geometry function
> > in fTools, which will create a copy of the dataset (as a shapefile)
> > with an additional length field (or it will populated the length field
> > if it already exists). From this you can use the compute basic
> > statistics function to get the sum of the field...
> Any chance to alter the fTools plugin so that the geometry functions
> stick the new columns straight into the original shapefile? I can't
> think of any situation where you'd need to keep both the original shape
> without the geometry attribute and the new one with.
> Other GIS software (i.e. GRASS as John Tull pointed out, as well as
> Arc*) just add the length/perimeter, X-Y  or area column into the
> existing vector layer.
> A minor annoyance, but it would be nice...
> Thanks,
> Micha
> > Hopefully that's what you are looking for?
> > Carson
> >> HI everybody
> >> i hope someone can help me with this:
> >> in a poly-line vector layer, which is obviously built of several
> >> festures, how can i add a column of LENGTH to the attribute table?
> >> then how can i SUM all of it?
> >> THNX
> >> T
> >> _______________________________________________
> >> Qgis-user mailing list
> >> Qgis-user at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/qgis-user
Lionel Roubeyrie
chargé d'études
LIMAIR - La Surveillance de l'Air en Limousin
http://www.limair.asso.fr
