[Qgis-user] No python on Fedora 10
dbnakuru dbakeman at comcast.net
Wed Mar 18 19:48:05 PDT 2009
For whatever reason you have to install the qgis-devel rpm to get this link
made for you.  It seems like an error in the packaging.
Micha Silver wrote:
> Micha Silver wrote:
>> José María Michia wrote:
>>> 2008/12/20 Micha Silver <micha at arava.co.il>
>>>> I've just finished setting up a F 10 machine, x86_64 with qgis and
>>>> GRASS.  I got the qgis rpms from the silfreed.net repo. It seems python
>>>> isn't recognized.
>>>> Here's are qgis  packages:
>>>> [micha at hayun-33 ~]$ rpm -qa | grep qgis
>>>> qgis-grass-1.0.0-0.1.pre2.fc10.x86_64
>>>> qgis-python-1.0.0-0.1.pre2.fc10.x86_64
>>>> qgis-1.0.0-0.1.pre2.fc10.x86_64
>>>> qgis-theme-classic-1.0.0-0.1.pre2.fc10.x86_64
>>>> and:
>>>> [micha at hayun-33 ~]$ python -V
>>>> Python 2.5.2
>>>> But no python plugins, and no python console.
>>>> What have I missed?
>>>> (Interstingly, GRASS 6.3.0 starts up on this machine with the wxPython
>>>> interface straight away.)
>>> I've had problems with Python plugins, in QGIS, and I've solved these
>>> problems by adding some paths to the system variable "PYTHONPATH"
>>> In my system:
>>> export
>>> PYTHONPATH=.:/usr/lib/python2.5/site-packages:/usr/local/share/qgis/python
>> Thanks. I tried that, but no joy. There was no env variable
>> PYTHONPATH. So I added it with:
>> export
>> PYTHONPATH=/usr/lib64/python2.5/site-packages:/usr/share/qgis/python
>> Still no python plugins.
>> Micha
> I think I've found the problem: Comparing with an Ubuntu installation, I
> see that there needs to be a soft link in /usr/lib64 from the
> libqgispython.so.x.x to libqgispython.so. Once I added the link, python
> worked.
> I guess package maintainers might need to add this in the postinstall.
> Thanks,
> Micha
>>> Saludos
>>> José María
>> This mail was received via Mail-SeCure System.
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
View this message in context: http://n2.nabble.com/No-python-on-Fedora-10-tp2038388p2500916.html
Sent from the qgis-user mailing list archive at Nabble.com.
