[Fwd: Re: [Qgis-user] Projection not recognised EPSG:31259]
Albin Blaschka albin.blaschka at gmail.com
Tue Mar 24 04:23:53 PDT 2009
Werner Macho wrote:
> Thx for your answers!
> But .. I assume a delivered projection file as correct - and you did not
> say that government fails or the projection is wrong ..
> The provided .prj from you are really nice - but i guess in fact it does
> not solve the problem.
> I just wanted to know where the problem is to investigate it..
> Are the .prj files wrong?
> does gdal/ogr something strange?
> is qgis acting wrong?
> so wheres the real problem behind this all?
 From my experience, ESRI/ArcGIS produces not really wrong, but
incomplete .prj-Files in regard to the "towgs84" - Parameter. I solved
the problem using the suitable .prj-file I sent with the last e-mail in
renaming it according to the shape file in question or copying the part
to the ESRI-generated .prj-file.
HTH!
Albin
| Albin Blaschka, Mag. rer.nat - Salzburg, Austria
| http://www.albinblaschka.info   http://www.thinkanimal.info
| It's hard to live in the mountains, hard, but not hopeless!
