[Qgis-user] Re: RGB composition plugin
Mauricio de Paulo mauricio.dev at gmail.com
Sun Mar 29 15:25:37 PDT 2009
	As a ubuntu user I also saw that problem. At the moment I'm using
GDAL's internals, not gdal_merge. You could say that the previous
version was based on gdal_merge as I read some of it's code to start the
plugin, but the recent upgrade is not really close to gdal_merge.
gdal_merge used the xml editing that I avoided in this version, so I
really implemented using python-gdal library. That's the only
requirement now.
	Hope it works fine. I still don't know how windows and mac users are
going to cope with python-gdal, but I think I saw the package in the
osgeo repository.
	All the best,
	MaurĂ­cio de Paulo
On Sun, 2009-03-29 at 23:33 +0200, Agustin Lobo wrote:
> I also think that we should use gdal as much as possible,
> the gdal_utilities are very good and I do use vrt files a lot
> for time series of images.
> But one problem is getting the appropriate gdal binary
> for the different unix distros. For example, the current
> gdal binary for ubuntu 8.04 (which is the LTS) is only 1.4.4 and does
> not have gdal_merge, I had to download it separately.
> How are you solving this problem? Are you including gdal_merge.py
> or are you relying on the latest gdal version (which is 1.6.0 I think)?
> Agus
> Mauricio de Paulo wrote:
> > Thanks for the interest, Augustin.
> > I've upgraded it to 1.0 API and made a huge change in code so that it
> > only uses gdal to set the VRT Raster, not xml messing anymore, so the
> > code should be more stable with gdal.
> > Again, the plugin is a gui to create a VRT raster colour composite. Gdal
> > does everything else by itself.
> > I should say that MANY features are being implemented in gdal through
> > VRT and other XML stuff (as wms). Maybe we should start thinking about
> > using VRT for other solutions (Filtering is the first easy one that I
> > think, but I truly think that gdal can war on the fly using vrt).
> > Thanks for testing,
> > MaurĂ­cio de Paulo
> > On Sun, 2009-03-29 at 11:16 +0200, Agustin Lobo wrote:
> >> Mauricio,
> >> It would be great.  Do you have it in a repository?
> >> Can we try it?
> >> Agus
> >>> I've written a RGB composition plugin using virtual raster and gdal.
> >>> Should I rewrite it to 1.0?
