[Qgis-user] Re: RGB composition plugin
Agustin Lobo alobolistas at gmail.com
Sun Mar 29 23:49:14 PDT 2009
I also think that we should use gdal as much as possible,
the gdal_utilities are very good and I do use vrt files a lot
for time series of images.
But one problem is getting the appropriate gdal binary
for the different unix distros. For example, the current
gdal binary for ubuntu 8.04 (which is the LTS) is only 1.4.4 and does
not have gdal_merge, I had to download it separately.
How are you solving this problem? Are you including gdal_merge.py
or are you relying on the latest gdal version (which is 1.6.0 I think)?
Agus
Mauricio de Paulo wrote:
> Thanks for the interest, Augustin.
> I've upgraded it to 1.0 API and made a huge change in code so that it
> only uses gdal to set the VRT Raster, not xml messing anymore, so the
> code should be more stable with gdal.
> Again, the plugin is a gui to create a VRT raster colour composite. Gdal
> does everything else by itself.
> I should say that MANY features are being implemented in gdal through
> VRT and other XML stuff (as wms). Maybe we should start thinking about
> using VRT for other solutions (Filtering is the first easy one that I
> think, but I truly think that gdal can war on the fly using vrt).
> Thanks for testing,
> MaurĂ­cio de Paulo
> On Sun, 2009-03-29 at 11:16 +0200, Agustin Lobo wrote:
>> Mauricio,
>> It would be great.  Do you have it in a repository?
>> Can we try it?
>> Agus
>>> I've written a RGB composition plugin using virtual raster and gdal.
>>> Should I rewrite it to 1.0?
