[Qgis-user] Re: [Qgis-developer] Feature requests
Lionel Roubeyrie lroubeyrie at limair.asso.fr
Mon Mar 30 01:38:45 PDT 2009
+1 for Maxim, the ArcGIS dispatching layers is great, we don't have to
worry about rearanging layers. Setting a raster or a polygon shapefile
above a point one is time consuming, because we always have to change
the order.
In the same behavour, the fact to have just one button to append
vector/raster/WMS file would be a pleasant solution to put files in
groups, like ArcGIS does.
Cordialy
Le samedi 28 mars 2009 à 13:57 -0500, Maxim Dubinin a écrit :
> >>  24. When opening a layer, add it to the position below the layer
> >>     selected in the legend (not always to the top)
> BR> -1 - when I add a layer I want to be able to see it, and if it's not
> BR> at the top I might not!
> When this is happening in ArcGIS, polygonal layers are being added to the
> bottom of the list, then lines, then points at the top. This is smart,
> especially when you load 10+ layers at once. Last layer is then
> selected, so you won't miss where it is now.
> Maxim
> Qgis-user mailing list
Lionel Roubeyrie
chargé d'études
LIMAIR - La Surveillance de l'Air en Limousin
http://www.limair.asso.fr
